[10155] Move screen when creating lines or faces / Chris
[Question] Response
Hi all,
I have my controls set up so that right click and drag is PAN. Middle mouse is rotate. When using CREATE I can click away making the lines, and rotate fine, but I can't PAN. Is there a way to do it? When I right click when using CREATE it simply stops the tool.
Thanks
2024-09-23 01:32
[10161] Re: Move screen when creating lines or faces / Administrator
There is a cross arrow icon in the upper right corner of the 3D view, so drag it with the left mouse button. Regardless of your mouse settings, you can also pan and rotate/zoom with the other icons.
2024-09-26 15:28
