Please create lines by the [Create] command after enabling the Lathe option.
2013-01-25 17:36
That's the thing, how do I enable Lathe option, there's nothing to click or enable.
2013-01-25 20:05
prop button on top of object panel. Lathe is on the right. Select axis and segments. Voila!
2013-01-26 00:37
Thank you very much. Got it to work.
Kind regards
Stuart.
2013-01-26 04:23
