[3310] Re: UV panel / Administrator
I named 'Select' because this option shows selected parts only.
Why do you think 'Isolate' is better?
2013-08-09 13:46
[3311] Re: Re: UV panel / Mark
It is more descriptive of the action and eliminates confusion with the other 'select'
2013-08-09 19:25
I'm afraid many people misunderstand 'Isolate' separates from neighbor faces or shows separated faces.
If 'Select' confuse you, I think 'Selected' is better than 'Select' and 'Isolate'.
2013-08-10 10:55
