Hello,
I have little request for the bend tool.
Currently making perfect 360 degree bend with only mouse needs some trial and error to have it done, otherwise it works fine. Would it be possible to have input field for the angle also, so it could be input from the keyboard if needed? Other option would be to make the starting bend point someway to snap for the end point to help both ends meet after bending.
2017-07-30 18:14
