Hi Administrator and others who kindly can offer help here,
Is it possible to know more details on how Metasequoia Measure the perimeter and an area of a 3D object?
In the software index, what is explained is very short, like this:
When you click any point on the object, it measures the object's perimeter including the point.
XY
It measures the perimeter parallel to the XY plane. (as usual, I do the measurement in this axis).
In [Perimeter], it measures the area of cross-section on the object.
Most of my 3d objects (short cylinders) have ellipsoid shaped cross-section rather than a true circular cross-section. So wanted to confirm the way the Metseq. calculate both perimeter and cross-sectional area of this ellipse.
Faithfully,
Alsayed
2019-03-05 17:10
