The problem doesn't appear if I switch to the "Ray Tracing" rendering mode, but the result is not that good
2023-10-23 21:01
And the "Scanline" mode works normally too
So the problem only appears in the "PBR" mode
2023-10-23 21:03
It is not possible to give an exact answer because the details cannot be seen from screenshots alone, but the rendering results may be inaccurate due to problems with calculation accuracy, such as when surfaces overlap.
Try checking the results using the simplest shape possible.
If you cannot find the cause, please send the relevant data to our support.
2023-10-24 10:35
