[10453] How group and ungroup objects using 4.9-0-d / Giovanni Chiozza
[Question] Response
Hello,
I'm beginning to use version 4.9 free version and I don't find the way to group and ungroup objects .
Could you please let me know how to use those function and overall where they are ?
Thanks
2025-10-24 22:05
[10454] Re: How group and ungroup objects using 4.9-0-d / Administrator
Metasequoia has a parent-child hierarchy function rather than grouping objects.
Pressing the '<' or '>' button in the object panel will make the object above it in the list the parent, or return it to the same hierarchy.
2025-10-25 10:35
[10455] Re: How group and ungroup objects using 4.9-0-d / Giovanni Chiozza
Yes but I need that a series of objects then work as one for instance when I move or scale them. Is it the same using hierarchies ?
2025-10-25 16:54
[10458] Re: How group and ungroup objects using 4.9-0-d / Administrator
Have you tried it yourself before asking this question? Try it out and then ask questions about anything you don't understand.
2025-10-27 08:25
