[10474] Shell/hollow Option / Chris
[Question] Response
Good morning,
I'm looking for a way to shell/hollow a 3d model. I can't see one. I think in the past I've perhaps had a single mesh surface which I have thickened to make it a certain size.
This time I used something called cotangent which is more a 3d mesh software for 3d printing but it has a really good shell option. Is this something that could be done with a script or something?
Thanks in advance
2025-11-20 16:23
[10480] Re: Shell/hollow Option / Administrator
The [Object > Voxeloid] menu includes a shell or a hallow generation function. However, depending on the resolution used during voxelization and re-polygonization, some detail in the original geometry may be lost.
Depending on the scene, this may not be an issue, but it may cause problems in practical use.
2025-11-24 21:05
