[8446] Two Suggestions / fzmnm
Greetings!
I love metaseq and I have two suggestions:
1) When mirroring is enabled, and one vertice was considered in the connection threshold, right-click merge should directly send the vertice to the mirroring plane
2) is there a short key for selecting loops/rings when in the move mode, instead of selection mode?
Thank you very much
2019-11-26 11:32
[8447] Re: Two Suggestions / Administrator
Please assign a short key to the [Belt] or [Edge loop] in [Select] by right-click on the button or call [Configuration] menu.
2019-11-26 18:00
