Hello , I am learning and writing a practical guide on Metasequoia . I can not understand the physical meaning of the operation “Move faces to a new object” . What does it do? How can I call this function on an object ? Please, if anyone understands how this function works, send me screenshots of the operation to my e-mail .Thank you.
2025-02-11 23:35
[10233] Re: Practical meaning of “Move faces to the new object” / Administrator
Please select faces and call the menu. A new object will be created and the selected faces will be moved from the original object to the new one.
2025-02-12 11:52
[10234] Re: Practical meaning of “Move faces to the new object” / Sergei
Thank you for your response. The problem was solved by painstaking observation. Here is its actual physical meaning:
When you create a new object, and you want to move a part of the polygons to the new object or “detach” from the parent object, the “Move” command will not allow you to do it - it will move the whole object. But when you use the “Move faces to a new object” function on the polygons you want to move, the command will “detach” these polygons from the parent object.
2025-02-12 13:54
