Tag has been changed from [Question] to [Question,スナップ].
[Rotate] command can be performed along either world coordinates (X/Y/Z axis directions) or the local coordinates of each object, which can be set with the [Local] command. You can also specify the angle directly using numerical settings, but there is no function to align it with an existing line, etc.
2025-08-25 16:34
