[10439] fill a closed polygon / paperPino
[Question] Response
How can I automatically fill a polygon with n points?
Thanks.
2025-10-10 20:07
Show the middle 2 messages.
[10442] Re: fill a closed polygon / Administrator
>Thank you for your prompt response, but it does not work. I do not have a hole within a mesh, I have a simple polygon made by points (more than four) and lines.
If you only have points and lines, you can use the [Object > Fill place surrounded by lines] menu, but this will only generate triangles and quadrilaterals, and will not generate faces with more than five sides.
Faces with five or more sides must be created manually using the [Create] command.
2025-10-11 23:00
