ログファイルの内容です。
_Installer.exe' to: 'C:\ProgramData\Package Cache\{612518cc-ce07-4395-8f6d-2178c7b6de1b}\Metaseq490e_x64_Installer.exe'
[219C:2E04][2026-02-14T19:47:14]i320: Registering bundle dependency provider: {612518cc-ce07-4395-8f6d-2178c7b6de1b}, version: 4.9.0.5
[219C:2E04][2026-02-14T19:47:14]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{612518cc-ce07-4395-8f6d-2178c7b6de1b}, resume: Active, restart initiated: No, disable resume: No
[219C:0DC0][2026-02-14T19:47:14]i305: Verified acquired payload: vc_redist.x64.exe at path: C:\ProgramData\Package Cache\.unverified\vc_redist.x64.exe, moving to: C:\ProgramData\Package Cache\7741A5CAD238CE3E4CA7756058F2A67A57FEE9D1\vc_redist.x64.14.29.30133.0.exe.
[219C:0DC0][2026-02-14T19:47:14]i304: Verified existing payload: X64 at path: C:\ProgramData\Package Cache\{C0EE36BF-0317-4949-B8B0-E2F0FAA136FE}v4.9.0.5\Metaseq490e_x64.msi.
[219C:2E04][2026-02-14T19:47:14]i301: Applying execute package: vc_redist.x64.exe, action: Install, path: C:\ProgramData\Package Cache\7741A5CAD238CE3E4CA7756058F2A67A57FEE9D1\vc_redist.x64.14.29.30133.0.exe, arguments: '"C:\ProgramData\Package Cache\7741A5CAD238CE3E4CA7756058F2A67A57FEE9D1\vc_redist.x64.14.29.30133.0.exe" /install /quiet /norestart'
[219C:2E04][2026-02-14T19:47:31]e000: Error 0xc0000005: Process returned error: 0xc0000005
[219C:2E04][2026-02-14T19:47:31]e000: Error 0xc0000005: Failed to execute EXE package.
[4688:0DAC][2026-02-14T19:47:31]e000: Error 0xc0000005: Failed to configure per-machine EXE package.
[4688:0DAC][2026-02-14T19:47:31]i319: Applied execute package: vc_redist.x64.exe, result: 0xc0000005, restart: None
[4688:0DAC][2026-02-14T19:47:31]e000: Error 0xc0000005: Failed to execute EXE package.
[219C:2E04][2026-02-14T19:47:31]i351: Removing cached package: vc_redist.x64.exe, from path: C:\ProgramData\Package Cache\7741A5CAD238CE3E4CA7756058F2A67A57FEE9D1\
[219C:2E04][2026-02-14T19:47:31]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{612518cc-ce07-4395-8f6d-2178c7b6de1b}, resume: None, restart: None, disable resume: No
[219C:2E04][2026-02-14T19:47:31]i330: Removed bundle dependency provider: {612518cc-ce07-4395-8f6d-2178c7b6de1b}
[219C:2E04][2026-02-14T19:47:31]i352: Removing cached bundle: {612518cc-ce07-4395-8f6d-2178c7b6de1b}, from path: C:\ProgramData\Package Cache\{612518cc-ce07-4395-8f6d-2178c7b6de1b}\
[219C:2E04][2026-02-14T19:47:31]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{612518cc-ce07-4395-8f6d-2178c7b6de1b}, resume: None, restart initiated: No, disable resume: No
[4688:0DAC][2026-02-14T19:47:31]i399: Apply complete, result: 0xc0000005, restart: None, ba requested restart: No
よろしくお願いいたします。
>https://xfs.jp/4BTvSnus
>上記URLを開くと「gamen.zip」というファイルがダウンロードできます。(firestrage:https://firestorage.jp/)を利用しました。
>この中にスクリーンショットを入れました。
>大変申し訳ありませんが確認していただけないでしょうか。
>>うまく言えないのでスクリーンショットを送りたいのですが、可能でしょうか。
>>よろしくお願いいたします。
>>>>Microsoft Visual C++ ****** Redistbutable (x64)
>>>>の******が20015-2019になっております。
>>>そこではなく、さらにその横の「14.xx.yyyyyyy」のような形式のバージョン番号はいくつでしょうか?
>>>あと、本当にVS2026を入れているのでしょうか?
>>>VS2026を入れているなら、2015-2019という表記になっているのが非常に違和感があり、やはり何かおかしいような気がします。
