>Was this model created within Metasequoia, or did you import external data?
Hi
All my models are created with Metasequoia since 2005, and the the french patch too, version LE R2.1 for the first one, if my memory is good.
I have just tried another time to be sure :
Create a basic primitive, apply fixed normal, scaling x10 with Scale in Local axis, and the result is the same :
https://i.goopics.net/fjeyto.jpg
https://i.goopics.net/tboxal.jpg
The fixed vectors are x10, not the non fixed vectors.
I hope this "little bug" can be fixed.
Bests regards.
JimmyMarco3D
