[10553] Fixed Normal vectors scaling problem and French Patch update / JimmyMarco3D
[Bug report] Response
Hi,
In my previous message, I haven't explained clearly the Fixed normal vectors scaling problem, so this screenshots show what happened when the Scale option is used in Local axis command :
https://i.goopics.net/0r6hgx.jpg
https://i.goopics.net/h2d8z8.jpg
https://i.goopics.net/640oin.jpg
The fixed vectors are x10 bigger when the Scale is setted x10.
Last update of the French patch.
https://www.aht.li/3959385/PatchFrancaisMetasequoia490f.zip
Bests regards.
JimmyMarco3D
2026-02-16 20:29
[10556] Re: Fixed Normal vectors scaling problem and French Patch update / JimmyMarco3D
>Was this model created within Metasequoia, or did you import external data?
Hi
All my models are created with Metasequoia since 2005, and the the french patch too, version LE R2.1 for the first one, if my memory is good.
I have just tried another time to be sure :
Create a basic primitive, apply fixed normal, scaling x10 with Scale in Local axis, and the result is the same :
https://i.goopics.net/fjeyto.jpg
https://i.goopics.net/tboxal.jpg
The fixed vectors are x10, not the non fixed vectors.
I hope this "little bug" can be fixed.
Bests regards.
JimmyMarco3D
2026-02-17 18:26
[10557] Re: Fixed Normal vectors scaling problem and French Patch update / JimmyMarco3D
https://i.goopics.net/4ipqbw.jpg
https://i.goopics.net/ynkdq6.jpg
I can do that all day long... I like Metasequoia.
2026-02-17 18:45
[10558] Re: Fixed Normal vectors scaling problem and French Patch update / Administrator
I've noticed that [Local] commands cause strange normals, so this problem will be fixed in the next release.
2026-02-18 16:34
[10563] Re: Fixed Normal vectors scaling problem and French Patch update / gery
>Hi,
