[7249] Re: bone dll fail to load / Administrator
Is the bone.dll for 64bit version of Metasequoia?
32bit or 64bit between Metasequoia and a plugin must be matched.
You should install 32bit version of Metasequoia to use the plugin.
2017-09-19 10:39
[7253] Re: bone dll fail to load / gaetan diotte
bone.dll file in Meta 64 plugin folder is date 2013.07.15 Where to find correct bone.dll for meta 64? Do I delete program and re-install?
arigato!
2017-09-20 22:51
I don't know bone.dll for 64-bit. All old plugins before Metasequoia 4 are for 32-bit only.
You must delete the bone.dll, install 32-bit Metasequoia, and put the bone.dll in the 'Plugins/Command' folder in 32-bit Metasequoia.
Otherwise, you should use a standard bone command in Metasequoia 4.
2017-09-21 09:59
