[7836] DXF import and export / benny boon
I don't see any mention of support for DXF format. This is important for compatibility with CAD like programs. So I would like to request for support of this format.
2018-10-06 04:42
[7837] Re: DXF import and export / Administrator
Metasequoia supports '3DFACE' only in dxf file. You must export a dxf file as 3DFACE if possible.
Otherwise, please use other file format like stl or obj if possible. DXF file is not suitable for transfering polygon meshes between softwares.
2018-10-09 09:46
