[8351] Precise Extrusion / fzmnm
Done [Request] Response
When I use extrude command, I can only drag the mouse to define the distance. I cannot enter an accurate number for the extrusion. Neither can I apply the snap setting to the extrusion.
So I want: 1. the grid snap setting apply to the extrusion command. 2. I can enter a number for extrusion
Thanks very much
2019-09-12 09:10
[8353] Re: Precise Extrusion / Administrator
Please call [Selected > Extrude faces] menu, and input an offset.
2019-09-12 11:46
