[9385] EDIT PANEL___Degree indicator / Tom Evers
Done [Bug report] Response
the Edit panel rotate use to say 90° not 4
2022-04-23 22:47
Show the middle 6 messages.
[9458] Re: EDIT PANEL___Degree indicator / Administrator
I found the cause for this problem. It seems that the angle notation becomes incorrect depending on the [Display unit].
We will fix this problem in the next release.
2022-06-17 13:10
