[9668] Change object's local axis via plugin or script / d4rt
Done [Question,local axis] Response
I have a few objects consisting of 1 face each. I need a way to automatically align the local axis of these objects with the faces' normal vector. Is it possible to do so via a plugin or a python script?
2023-02-11 01:20
Show the middle 7 messages.
[9689] Re: Change object's local axis via plugin or script / no error in code.
need snipped to move Obj1 to up bit and rotate 180  in 3dview port with py script ! :S
2023-02-15 17:28
