[9674] FILE> EDIT> attribute> selected> object Delete Lines / Delete LINES
Not necessary [Request,help! ] Response
import MQSystem
doc = MQSystem.getDocument()
objnum = doc.numObject
for oi in range(0, objnum):
    obj = doc.object[oi]
    if obj is None:
        continue
    if obj.name == "obj":
        obj.select = 1
        break
hmm i cant find to delete Lines in there :/  so script editor deletes lines for me ! doing script but cant find that one :S
2023-02-13 13:38
Show the middle 2 messages.
[9681] Re: FILE> EDIT> attribute> selected> object Delete Lines / Administrator
Don't you understand what 'pseudo code' means?
It doesn't work as is, so you need to make your own improvements to incorporate it.
See more standard samples included in the Script folder.
2023-02-14 14:04
