[9801] Re: Feature Request - UV Pixel Alignment / Administrator
Your feature request has already been fulfilled.
>1. Can we get the option to turn off bilinear in UV screen?
Check the [Preview > Direct3D(or OpenGL) > Show textures smoothly] item off in the [File > Configuration] menu.
>2. Can we get option to snap UV coordinates to pixels with the given texture we are mapping?
In the [UV Edit > Config] menu,
* Set the [Grid] value equal to the texture resolution.
* Chech the [Snap to the center of grid] item on; if necessary.
And, turn [Grid] and [Snap] on in the UV view.
2023-10-23 10:12
[9802] Re: Feature Request - UV Pixel Alignment / Carl
Hello! and thank you! This has helped me, but the grid snap appears inacurate, I can not properly set the resolution which means the gird snap is actually uneven, vertically the grid appears to be two blocks of pixels, but horizontally it is 1.
2023-10-23 17:01
Specifically, it appears we can not pick a vertical resolution, only horizontal. Could this be added? Or perhaps a feature to automatically adjust based on image resolution?
2023-10-23 17:11
