hello, long time metaseq user here, in recent updates i've noticed the blinn shader was removed from the software, well the issue is that i have a bunch of old files where i used the blinn shader quite a lot and now some cant be opened quite right, theres this file in particular that is quite big and it straight up crashes the program and i cant go to the materials tab and replace the blinn shader with anthing else, what should i do?
2023-11-04 14:27
