[9856] Compatibility with "Big-Little" and Windows 11 / User
Done [Question,compatibility] Response
Hello, I was wondering if Metasequoia is fully compatible with the newer intel architecture, the one with big and small cores? Will the rendering work ok with it?
2024-01-03 00:28
[9858] Re: Compatibility with / Administrator
Although it is not optimized for a specific CPU manufacturer or architecture, it is made faster by actively using multi-cores. Although not all functions utilize multi-core, path tracing rendering is the feature that benefits most from multi-core. Try checking the CPU usage in Task Manager.
2024-01-05 12:22
