[10387] Rotate around a specific axis / Chris
[Question,スナップ] Response
I amd trying to figure out if there is a way to rotate/array whatever you want to call it around a no normal axis. So I have a model which is on an angle. It needs some repair so I am remodeling some parts. Once I've modeled the part I need to circular array them around the axis of the part that is on the angle. Is there a way to do it?
Thanks
2025-08-23 06:44
[10391] Re: Rotate around a specific axis / Administrator
Tag has been changed from [Question] to [Question,スナップ].
[Rotate] command can be performed along either world coordinates (X/Y/Z axis directions) or the local coordinates of each object, which can be set with the [Local] command. You can also specify the angle directly using numerical settings, but there is no function to align it with an existing line, etc.
2025-08-25 16:34
