Otsukaresama desu.
I would like to be able to select 4 or more vertices. After selecting, I would like to align those vertices against a plane or a face.
For the baseline plane or face, maybe the first 3 selected vertices can be used.
Is this possible with the current functions available in metaseq?
Ijou, yoroshiku onegai itashimasu.
2020-11-11 17:47
[8858] Re: Align selected vertices along a plane or face. / Administrator
Please operate the following steps when a face is selected.
* Switch [Edit Option] > [Snap] > [Plane] on.
* Click an icon at the right side of the [Plane] menu.
* Check the [Arbitrary] in the [Plane Setting].
* Push the [Get from a selected face] button.
You can move vertices with snapping on the selected face.
And, you can also use the [Selected > Planation] menu if you just want to align all selected vertices.
2020-11-12 17:07
[8859] Re: Align selected vertices along a plane or face. / Eric
ありがとうございます!
2020-11-12 17:27
