[9076] Color mapping on export to DōGA CGA / Todd Zircher
[Question,DOGA] Response
When exporting models into the DōGA library, colors/materials do not always map properly.  Is there a list of color names that Meta 4 uses?  It does not seem to match genie.atr since some names do work while other fail to render in the thumbnail or show up in the SUF file.
2021-07-15 13:02
[9077] Re: Color mapping on export to DōGA CGA / Administrator
Which version of DoGA CGA System do you use?
2021-07-15 20:53
[9079] Re: Color mapping on export to DōGA CGA / Todd Zircher
L3, the las one that Team DoGA released.
2021-07-15 22:29
[9083] Re: Color mapping on export to DōGA CGA / Administrator
When you export to DOGA-L series, the model must be assigned  materials that are loaded from genie.atr.
The function of loading .atr files is obsolete in the latest version, so please use Ver4.6.9 or older versions.
And, the function to export parts to DOGA-L series was designed DOGA-L1 and L2 which didn't have a modeling function. Since the structure under the common folder is the same between DOGA-L1/L2 and L3, you can export to DOGA-L3, but it is not optimized. Therefore, please edit the part within DOGA-L3 if necessary.
DOGA-L3 is now very old software, so we no longer know the details.
2021-07-17 14:07
[9084] Re: Color mapping on export to DōGA CGA / Administrator
One correction. It is only the output that is obsolete, so it can be imported in the latest version.
In any case, detailed support is no longer available.
Please make sure that the material name in the .suf file, the definision in .atr file, and texture location are appropriate.
2021-07-17 14:23
[9085] Re: Color mapping on export to DōGA CGA / Todd Zircher
Thank you for the answer.  Just for your information, in the latest build of Meta, export to L3 almost works.  The only problem is that the export does not map to every color in the ATR file.  That might be that the L1/L2 materials are a subset of L3 or that the names have changed on some materials.  It gives me something to look for at least.  Thanks again.
2021-07-17 14:32
