[9385] EDIT PANEL___Degree indicator / Tom Evers
Done [Bug report] Response
the Edit panel rotate use to say 90° not 4
2022-04-23 22:47
[9386] Re: EDIT PANEL___Degree indicator / Tom Evers
>the Edit panel rotate use to say 90° not 4 Deg
2022-04-24 06:59
[9387] Re: EDIT PANEL___Degree indicator / Tom Evers
>ok  it works correctly on my other  PC and laptop, I can not find a setting to change it stopped working maybe a year ago
2022-04-25 07:05
[9388] Re: EDIT PANEL___Degree indicator / Administrator
When the rotation button in Edit Panel is dragged, it rotates by 15 degrees if the Shift key is pressed, or by any angle if not pressed.
2022-04-25 13:59
[9395] Re: EDIT PANEL___Degree indicator / Tom Evers
>When the rotation button in Edit Panel is dragged, it rotates by 15 degrees if the Shift key is pressed, or by any angle if not pressed.  YES I know that, thankyou, but that does not fix my problem.. here are pictures..https://drive.google.com/drive/folders/1zT_Z9w1pqY4VRMoIN0B1cacoDPnMoLDv?usp=sharing
2022-04-29 15:03
[9447] Re: EDIT PANEL___Degree indicator / Tom Evers
>When the rotation button in Edit Panel is dragged, it rotates by 15 degrees if the Shift key is pressed, or by any angle if not pressed.Did you look at my pictures?????? the problem is still there.
2022-06-12 02:41
[9453] Re: EDIT PANEL___Degree indicator / Administrator
When I check the operation, nothing is wrong and it displays correctly. I have no idea why it is like your case.
2022-06-14 12:32
[9458] Re: EDIT PANEL___Degree indicator / Administrator
I found the cause for this problem. It seems that the angle notation becomes incorrect depending on the [Display unit].
We will fix this problem in the next release.
2022-06-17 13:10
