[9440] Request for feature / Colin Buley
Will you or can you ever save files with textures?
I regularly use meta for editing files from outfit studio and have to export as OBJ and after editing in meta re-inport back but have no textures. I work around it but it would be great if the option was supported in meta!
Regards Colin
2022-06-09 01:33
[9441] Re: Request for feature / Administrator
It would be best at this time to place the texture files in the same folder as the mqoz files, and specify the textures as relative paths.
Carrying the entire folder will ensure that no files are missing.
2022-06-09 09:30
[9442] Re: Request for feature / Colin Buley
2022-06-09 15:00
[9443] Re: Request for feature / Colin Buley
Outfit Studio has its textures in a seperate pathed folder to its meshes so gathering those textures when exporting in some way would be time consuming at best. Could you suggest a simpler easier to understand option which may be included in a future release of meta?
Regards Colin
2022-06-09 15:05
