[9804] What am I doing wrong? / User
Done [Question] Response
I'm trying out the new rendering method(PBR), but I seem to be missing something. For some reason a mask texture appears completely opaque in the result, even though it's ok in the preview
Screenshots:
https://imgur.com/a/HoBP0u2
Am I missing something?
2023-10-23 20:12
[9805] Re: What am I doing wrong? / User
The problem doesn't appear if I switch to the "Ray Tracing" rendering mode, but the result is not that good
2023-10-23 21:01
[9806] Re: What am I doing wrong? / User
And the "Scanline" mode works normally too
So the problem only appears in the "PBR" mode
2023-10-23 21:03
[9807] Re: What am I doing wrong? / Administrator
It is not possible to give an exact answer because the details cannot be seen from screenshots alone, but the rendering results may be inaccurate due to problems with calculation accuracy, such as when surfaces overlap.
Try checking the results using the simplest shape possible.
If you cannot find the cause, please send the relevant data to our support.
2023-10-24 10:35
[9808] Fixed (I don't know why) / User
I've created a new material with the same settings (and textures) and it works now, stops working when I switch back to the old one.
I don't know what causes the problem, but I guess it's fixed for now
(just leaving this here in case somebody else gets this problem)
2023-10-24 15:07
