起動直後に表示>レンダラー>OpenGLに切り替えるとクラッシュしてしまいます。
以下エラーログの内容です
Windows version : Windows 10 x64 22H2  Build:19045
Number of CPU : 16
Physical memory : 31863 MB
Direct3D11 Driver: AMD Radeon RX 7800 XT
    DeviceID: 29822
    SubsysID: 1197088162
    Revision: 200
    FeatureLevel: 11.4
OpenGL Renderer: AMD Radeon RX 7800 XT
  OpenGL Version: 4.6.0 Compatibility Profile Context 24.8.1.240822
  GLSL Version: 4.60
Failed to compile a shader: C:\Program Files\tetraface\Metasequoia4\HLSL\glsl\vs.vert
ERROR: 0:1: '#version' : bad profile name; use es, core, or compatibility
ERROR: 0:1: '#version' : bad tokens following profile -- expected newline
ERROR: 0:1: '' : compilation terminated
ERROR: 3 compilation errors.  No code generated.
Failed to compile a shader: C:\Program Files\tetraface\Metasequoia4\HLSL\glsl\phong.frag
Failed to compile a shader: C:\Program Files\tetraface\Metasequoia4\HLSL\glsl\faceline.vert
Failed to compile a shader: C:\Program Files\tetraface\Metasequoia4\HLSL\glsl\faceline.geom
Failed to compile a shader: C:\Program Files\tetraface\Metasequoia4\HLSL\glsl\faceline.frag
