[10440] Re: fill a closed polygon / 管理者
Please use the [Hole] command.
You can fill all holes automatically or manually select specific holes.
2025-10-11 14:08
[10441] Re: fill a closed polygon / paperPino
Thank you for your prompt response, but it does not work. I do not have a hole within a mesh, I have a simple polygon made by points (more than four) and lines.
Thanks
2025-10-11 17:04
If you only have points and lines, you can use the [Object > Fill place surrounded by lines] menu, but this will only generate triangles and quadrilaterals, and will not generate faces with more than five sides.
Faces with five or more sides must be created manually using the [Create] command.
2025-10-11 23:00
