[2909] Mr / Jim Brand
[質問] 返信
Is there away to make my model semi transparent in ortho views please?
2013-01-03 19:55
途中の3件のメッセージを表示
[2916] Re: Re: Re: Re: Mr / Jim Brand
>Sorry, I misunderstood it was not one of three orthogonal views but an orthogonal 3D view.
>An alpha is not applied on the three orthogonal views because an alpha in the view that cannot be rotated has a low visibility and it does not make much sense.
Thank you, Metasequoia is the only modeller that does not support alpha in the ortho views.
I will have to stay with Silo until Metasequoia catches up,thanks again for your help.
2013-01-05 00:09
