[2984] release notes / airflamesred
[質問] 返信
A bump map image or a normal map image can be specified for the [Bump] mapping in the material property.
Is this a display feature?
Added [Convert to normal map] in the menu of the paint panel.
This option seems greyed out. I assume this is a feature in development?
2013-02-04 09:47
途中の4件のメッセージを表示
[2995] Re: Re: Re: Re: release notes / airflamesred
After some investigation I have direct X 10.1 and shader 4.1. I have checked all your suggestions.
2013-02-07 02:43
