[3225] beta 4 - bug report / Mark
[不具合報告] 返信
Thank you for the opportunity to test.
Grid options not available in edit options - can not remove the XZ grid.
Right click 'register to tool panel' not working on Anguwrap - I think because plug in?
Edge extrude with shift only according to screen = I think world coords is correct.
Edge loop selection seems erratic when reaching a pole.
2013-08-04 02:44
途中の5件のメッセージを表示
[3351] Re: Re: Re: Re: beta 4 - bug report / Mark
>>Edge extrude as predefined with the shortcut 'H'
>I see. I misunderstood it's the extrude command.
>Only dragging operation can move on the two directions, not three axes. Therefore, it moves on the screen coordinate. And it can move along X, Y or Z axis on the three orthogonal views.
Maybe confusion here?
I refer to 'pull face' as defined. If selecting in perspective, the extrusion is constrained to screen. It is impossible to make a selection in orthagonal - catch 22!
2013-08-13 21:04
