[3226] Over view / Mark
[Ver4β] 返信
The new interface is very nice.
The introduction of n gons, I think is bad, for beginers this could cause problems.
There are still too many options for local axis - I think this can be much simpler.
I don't understand the mapping tag - can not test this.
Tetraball - I don't understand.
Bevel extrude with angle at zero (inset)- very nice.
thank you
2013-08-04 02:56
途中の5件のメッセージを表示
[3292] Re: Re: Re: Over view / 管理者
Thank you, Mark.
'Local' command and 'L' options were added later than other editing functions without arrangement of them, and I think it makes different to understand.
2013-08-08 18:11
