[3505] Wgt options / germaine
[要望,wgt options+] 返信
Hello,
My question is can you put in so u can see all the wgt numbers on a model? so u can enable numbers. sometimes i forgot what to select. so i had to click every point to see wich number it was. also can you make it so u can add to +3.00 wgt instead of just 1.00 as highest?
2013-09-11 15:12
