[5079]
No Taskbar access
Nick
[Bug Report maybe]
OS: Win 8.1 32 bit
Metasequoia 4.3.2.
I have noticed that when Metasequoia window is maximized I cannot pop up the OS taskbar by moving my cursor to bottom of the screen.
Is Metasequoia window "Stay on Top" of taskbar?
2014-12-14 10:57
[5081]
Re: No Taskbar access
The window is not "stay on top". However, a taskbar will be hidden behind the window if you set to hide a taskbar automatically.
We are under investigation. Pelase wait for a while.
2014-12-15 16:39
>The window is not "stay on top". However, a taskbar will be hidden behind the window if you set to hide a taskbar automatically. > >We are under investigation. Pelase wait for a while.
