[5133] Axes for Blender / Nick
[雑談] 返信
Bug maybe in Metasequoia 4.3.4.
The axes diagram in the export Dialog when you select Blender has changed from Metasequoia 3.
See attached images.
ファイル [BlenderAxes.jpg]
2015-01-04 16:43
[5144] Re: Re: Axes for Blender / Nick
タグが [不具合報告] から [雑談] に変更されました。
OK. Thanks for your reply.
I think the menu item "Join closed vertices" in English Metasequoia should actually be "Join close vertices".
"Closed" means "not open".
2015-01-06 09:38
