[5170] How to make child object in plugin code / nick
[質問] 返信
Metasequoia 4.3.4, Win8.1 32bit, SDK 4.3.3, VS2013 Community Edition
I am writing an import plugin but cannot create child objects.
objclone->SetDepth(1) does set depth to 1 but depth is 0 after AddObject(objclone).
What am I doing wrong?
    MQObject obj = MQ_CreateObject();
    // obj's vertices and faces are read from a file
    MQObject ob = MQ_CreateObject();
    doc->AddObject(ob); // add empty object
    for (int i = 0; i < 4; ++i)
        MQObject objclone = obj->Clone();
        objclone->SetDepth(1);
        doc->AddObject(objclone); // objclone is not child of ob. Why?
2015-01-26 12:34
[5172] Re: How to make child object in plugin code / Nick
OK. Thank you.
2015-01-26 18:53
