[5174] API Documentation / Nick
[質問] 返信
MQBasePlugin::GetPluginClass() does not appear as member of MQBasePlugin class in API documentation.
Should it be in the API documentation?
The following sentence appears in the API document and is confusing.
"No additional implementation is not necessary in an inherited class."
Could you clarify/re-translate please.
Thank you.
2015-01-30 16:29
途中の2件のメッセージを表示
[5177] Re: Re: API Documentation / 管理者
The documentation is a supplement to SDK header files and sample codes. There is an explanation of SDK core only, and it is not written for convenient functions, like MQ3DLib and so on. Please refer sample codes to implement effectively.
"No additional implementation is necessary in an inherited class" is correct. 'not' is wrong. We'll fix it.
2015-02-02 12:05
