[6513] Error after Download / ingrid
対応不要 [不具合報告] 返信
I downloaded the 64-bit newest version, but when I try and open the file it doesn't work. Nothing happens. I tried to download the 32-bit to but the same thing happened after. Why? Right now there is no way for me to start metasequoia at all.
2016-05-07 22:05
[6518] Re: Error after Download / 管理者
Which version of Windows do you use?
I imagine you have some problems in Windows Installer, but I'm not sure because there is little clue. Did you restart Windows and try to install again?
2016-05-09 09:58
