[6545] about Object name / Yanh Jin Guk
[不具合報告,Object name] 返信
Hello... Mizuno... Many thanks for your software.
I buy Meta...4EX version. Now I tested trial version.
I found one problem.
This is Korea and used Win10.
I opened old my 3d files to make meta...3.
And I found blank in object list of object panel.
Maybe Korean not supported.
So... I try make new... But same error...
If I type Korea... out put is blank(box).
Pls inform for solve it.
2016-05-14 13:55
[6550] Re: about Object name / Yang Jin Guk
Don't solve it... Do you have other ways?
2016-05-17 18:30
