[6645] Perspecitve settings / MarieRose1301
対応済み [質問] 返信
Hello I've somehow changed the perspective settings but can't find how did I do it, is it possible to reset them?
ファイル [Capture.PNG]
2016-07-04 18:59
[6646] Re: Perspecitve settings / 管理者
This display is caused by the huge FOV. You can adjust the FOV in the [View panel] in the [View] button above the view. And, you can also reset the view by the [Reset] menu in the [View] button.
2016-07-05 11:31
