[6645]
Perspecitve settings
MarieRose1301
[質問]
Hello I've somehow changed the perspective settings but can't find how did I do it, is it possible to reset them?
ファイル [
2016-07-04 18:59
[6646]
Re: Perspecitve settings
This display is caused by the huge FOV. You can adjust the FOV in the [View panel] in the [View] button above the view. And, you can also reset the view by the [Reset] menu in the [View] button.
2016-07-05 11:31
