[6783] Broken .mqx file? / MarieRose1301
対応済み [質問] 返信
Hello,
the same issue from the old post happened again when there was RAM overload and the program terminated itself
The .mqo and .mqx files have not been deleted and it doesn't seem like they have been edited, but for some reason the bones won't load anymore. Is it possible to recover it?
These are the files: http://sta.sh/01o9fxg8wuvl
2016-12-10 03:30
[6787] Re: Broken .mqx file? / まじかる☆しげぽん
横から失礼します、現状mqxファイルはバックアップされないとのことですがmqxファイルもバックアップ対象に含めてほしいです。
ボーン作業中に落ちた場合、mqxファイルがバックアップされておらず以前の状態まで巻き戻ってしまうのは致命的です。
問題が起きた際の自動バックアップは、mqo、mqxの両方をバックアップするのに対応お願いします。
Excuse me from the side, I heard that the current mqx file will not be backed up, but I want the mqx file to be included in the backup target.
If it fails during bone work, it is fatal that the mqx file is not backed up and it rolls back to its previous state.
For automatic backup when problems occur, please support both mqo and mqx backup.
2016-12-10 20:52
