[7285] Numpad not working for keyboard shortcuts / Daniel Navarro
対応済み [不具合報告] 返信
I was on Metaseq 4.5 and had the Numpad configured to change between different view angles. Now I'm on 4.6 and I can configure the view angle to numbers but they only work with the numbers on top of the letters not the numbers on the NUMPAD. I had numlock activated and the Numpad is working normally for typing in and out of Metaseq, it just wont work for shortcut.
Help!
2017-10-20 07:05
[7286] Re: Numpad not working for keyboard shortcuts / 管理者
Which version of Metasequoia do you use?
A bug of shortcut key exists in the version from 4.6.0 to 4.6.2, and it has been fixed in ver4.6.3. Please update the latest version.
2017-10-20 12:29
