[7633]
want to save measured values
Alsayed
[質問]
Hi all,
I am using the software to measure the diameter and areas of many 3d objects. after the value appeared
2018-05-08 16:30
[7634]
Re: want to save measured values
Alsayed
>Hi all,
>I am using the software to measure the diameters and areas of many 3d objects. after the value appeared on screen, how can I save them or import the values to excel or word files??
thanks,
2018-05-08 16:33
>>Hi all, >>I am using the software to measure the diameters and areas of many 3d objects. after the value appeared on screen, how can I save them or import the values to excel or word files?? >thanks,
