[7648]
MQO file normals format
Nick
[質問]
What is complete specification for normals in .mqo file?
e.g. What do the four 2 mean?
N(2 2 2 2 -0.57735 0.57735 0.57735 0.57735 0.57735 0.57735 0.57735 -0.57735 0.57735 -0.57735 -0.57735 0.57735)
2018-05-17 15:24
[7650]
Re: MQO file normals format
The head values mean a combination of the following mask-bits;
1: Hard edge
2: Fixed normal vector
And, normal vectors follow after the mask-bits if a fixed mask-bit is enabled.
2018-05-17 17:57
[7653]
Nick
Thanks
2018-05-18 14:40
>The head values mean a combination of the following mask-bits; > 1: Hard edge > 2: Fixed normal vector > >And, normal vectors follow after the mask-bits if a fixed mask-bit is enabled.
