[8260]
UV Texture file with Lines
Tom
[質問]
Can I save a texture file to show the UV lines, so I can edit it in photoshop or other art program?
Example...
http://www.metaseq.net/en/tutorial/image/v460_10b.png
Thank You
2019-05-23 08:21
[8261]
Re: UV Texture file with Lines
Tom
OK I found Export, problem solvled... Thank you anyways
2019-05-23 09:41
>Can I save a texture file to show the UV lines, so I can edit it in photoshop or other art program? >Example... http://www.metaseq.net/en/tutorial/image/v460_10b.png >Thank You
